#3862783
Hi all I'm trying to find some honda centre caps for my new evo wheels. Has anybody made there own or can they be brought had a look around but can't find any that I like.
By Ray16138
#3862806
N77 wrote:I just got some H badges made the size and stuck them over the mitsubishi ones.
Sent from my SM-G935F using Tapatalk
Hi mate, what size is this centre caps? Mine wheel has these missing, and I'm sure you could buy these caps with Honda stickers on them from eBay just need the hole size?
#3862809
Hi mate thanks for you reply yea I've got the wheels all sorted now [emoji106]. I brought some centre caps off ebay so will see what they look like when they get here lol. An they are 60mm as I was told that's what the Mitsubishi ones are.
#3862810
nissan_pulsar wrote:Hi mate thanks for you reply yea I've got the wheels all sorted now [emoji106]. I brought some centre caps off ebay so will see what they look like when they get here lol. An they are 60mm as I was told that's what the Mitsubishi ones are.
Hi, the 60mm is outer size or inner, I've check 55mm inner size is for 59mm outer, so I'm confused should I order inner size for 55mm. Do you have a link from what you've got?
#3863239
nissan_pulsar wrote:Hi 60 mm is the outer part the bit you see lol and yea I will give you the ebay item number : 252649614839. Hope it helps
Hi, wer these one sort the enkei wheels out? I wasn't return to this topic, bought a 60mm caps from somewhere in eBay and they too big to fit, will buy those if they fit ok.
