I'm considering buying some evo 8 wheels for trackdays but intend to keep the stock wheels for road tyres.
Problem is, I need to run 10mm spacers (eibach with longer studs) for the BBK I've purchased and wonder if it's possible to easily remove the spacers and fit the evo wheels?
The only issue I can see is the longer studs might not allow the nuts to fully tighten and clamp the wheel. Anyone know if I can purchase longer nuts, or if the standard evo nuts will fit on the longer studs?
If it's not possible I'll have to find another set of oem wheels, just fancied the extra width.
