By trev27
#3777050
When replacing the discs front and rear, does the caliper need to come off or can
it be just moved out of the way??? Reading the Civic Haynes manual (obviously not for
the type r ) they say it has to be removed. Cheers
By Lewisgame
#3777069
You'll have to remove the caliper to change the pads.
There'll then be a caliper carrier. This will need to be removed to take the disc off.
By Lewisgame
#3777070
By trev27
#3777085
So it needs completely removing and disconnecting, then the brakes need to be bled once the new disc is fitted???
