By decoep3
#3714258
I am just finishing off a brake conversion on my ep3 .
Evo 5 calipers and discs .looks and size are savage compared to any other brakes .
https://www.dropbox.com/sc/ukr9a3gxbobm10i/vnpVragjsy
As I said I am not finished yet , calipers need painting and different evo wheels going on car .
Im wondering would there be much of an interest in these modifications . Pritty much BOLT ON with spacer and caliper bracket . no welding or mods to carrier etc needed .
By Col R
#3714402
Sounds good :shouldbeinteresting:
By decoep3
#3714450
https://www.dropbox.com/s/okjxkiu21du8m ... 423d-V.jpg
https://www.dropbox.com/s/h7hky8pstpw7t ... d905-V.jpg
https://www.dropbox.com/s/l6roaavo5bs8r ... af3c-V.jpg
https://www.dropbox.com/sc/i6l4wbs1n3he2ds/AghNxapuaz
I am nearly finished my car and everything has been fitted .
The spacers require wheel studs and bolt directly to the standard hub .
studs wont be supplied with spacers and can be got from honda or extended ones from tegiwa . Then nuts to bolt spacer to your hub as seen in photos .
The spacers sit behind the disc and to use evo brakes you will require aftermarket wheels . Recommend evo 5 as seen in photo
Id say €400
By CrouchyM
#3714519
Be good if you supplied everything ready to bolt on without sourcing bits from elsewhere.
By decoep3
#3714550
Brackets and spacers work out €400 euro . Im in ireland .
If I was to supply with studs in spacers average price for 10 studs is about 60 euro or more from honda .
then require hub centric wheel nuts to hold spacer on (or what I did was thread locked and put wheel nuts on . Then angle grind off top flush so disc can sit on )nuts where €35 . I think hub centric are more expensive but dont require cutting .
By decoep3
#3714874
J wrote:Safer to but something tried and tested.
Forgot to mention this setup has been used on a time attack ep3 in Ireland for the last two years with no issues
