evilowl wrote:TiVoMD wrote:when you say you have to change the RBF600 fluid every 4 - 6 months, is this ALL DOT4 fluids.
Yes, glycol based fluids are hygroscopic and will allow moisture into the system, over time the boiling point will be reduced
TiVoMD wrote:If so, I'm looking towards Motul DOT 4 brake fluid 100% synthetic. What do you think? As I can afford to change this fluid every 6 months. .
Try it and see how you get on, if you boil the fluid then get better stuff next time round
hi owl, is the halfords dot5.1 ok?or should i get dot4? and how much will be needed.. as i am getting front pads and disks and brakelines fitted. and i will be getting the brakes bleeded
i have ordered some ferodo ds2500 front pads, bought some do luck brakelines, and front mintex discs. so just waiting for ds2500 to be delivered..
also i noticed today when i reversed it was making a funny squeaking noise bought rear discs in may09 and as far as im aware the rear pads looked pretty new and still new from when i looked at them when i got new tyres put on a few weeks ago..
also for some reason when i drive over 55-60mph and i press the brakes the car seems to pull to the left any ideas what it could be?or is it a case front passenger side pad is worn down more?
sorry for all the questions :thumbup:
hope u can help as im worried why its pulling to the left. as it doesnt do it when im driving at below 50mph and anything over this it does..?
