Got an discussion that needs a majority verdict? Put it to the vote.
Will the plane take off?
Yes (after thinking about it :D) third poll
51
54%
No (after thinking about it) third poll
28
30%
i'm going for the mong paradox
4
4%
i'm just simply a mong and don't understand physics
2
2%
i'm a mong
4
4%
mong
5
5%
By MartinR
#1422108
Found this on another forum.
Here is kind of a brain teaser...
A plane is standing on a runway that is made of a large conveyor belt. The plane fires up its engines, but as it moves forward, the conveyor belt senses the speed of the plane's wheels and moves at exactly the same speed in the opposite direction. Can the plane take off?
By AMR79
#1422125
CIVICUS wrote:No
What if its a harrier jumpjet? :D
By mosizlak
#1422126
how does the conveyor belt sense the movement of the wheels??
The wheels are'nt driven on an aeroplane.
By fingery
#1422127
Yes.
Irrelevant what the wheels are doing as forward motion is provided by thrust from the engines and not the wheels.
By AMR79
#1422129
mosizlak wrote:how does the conveyor belt sense the movement of the wheels??
lol theres always one :wink:
By fingery
#1422130
AMR79 wrote:
CIVICUS wrote:No
Wheels wouldnt be moving :wink:
By alanb
#1422133
yes although its speed is zero relative to the conveyor belt its 200 mph relative to the ground
By CIVICUS
#1422136
surely the speed that the plane would be doing once the wheels left the ground , would cause the plane to be propelled forward at such a velocity that it would crash
By mosizlak
#1422138
fingery wrote:Yes.
Yeah but the movement has to start somewhere and as the wheels turn this conveyor belt senses the movement of the wheels and exactly matches it??
By eatthis
#1422142
Yes because the plane is driven by prop/jet not road wheels
By mosizlak
#1422143
fingery wrote:Turned to poll :lol:
:lol:
By alanb
#1422148
mind u the thrust forward is negated by the frictional force of the conveyor belt all the energy is likely to be transferred to heating the belt so .................. no
By Ali
#1422151
Assuming they meant the conveyor belt matches the plane's speed, then no as there would be no increase in air speed under the wing and no build up of pressure.
If the speed was measured from the wheels (which still rotate at a speed, regardless of whether driven) then the same would still happen.
By mosizlak
#1422152
alanb wrote:mind u the thrust forward is negated by the frictional force of the conveyor belt all the energy is likely to be transferred to heating the belt so .................. no
making the belt expand??
Thing is whoever designed this airport runway belt (for whatever f**king reason) would have taken heat expansion into account and added in a tensioner.
By Ali
#1422153
Unless he was British and it was Friday afternoon....
By fingery
#1422154
Where's Bumblebee or GriegR when you need a pilot :roll: :lol:
By mosizlak
#1422155
fair comment on the Friday afternoon but the tensioner would have had the biggest most expertly wound spring on it. Lets not bash British engineering.
By Dyls
#1422157
I'm guessing no since the plane isn't moving through the air which creates the lifting force.
  • 140
