Page 1 of 5
Boost pressure drops dramatic
Posted: Sun Jul 10, 2016 12:12 pm
by ruffstuff77_GER
Hi everybody.
Now that the summer has come I found out that my (and other) CTRs do not like high temps.
When I push it hard the boost pressure drops down to 1.0-1.1 bar (14,5-16 psi).
This means less power and this is not funny. Honda say there is no Problem and everything is fine.
I dont think so!
Anyone else with this experience? Any solutions?
Re: Boost pressure drops dramatic
Posted: Sun Jul 10, 2016 1:53 pm
by Loxy
What were the ambient temps and oil temps during you boost losses?
I've not had any issues myself.
Posted: Sun Jul 10, 2016 2:09 pm
by Dragonfall
Not had this issue and none of the other FK2 owners I know have reported anything like this?
Under what circumstances are you experiencing this?
Posted: Sun Jul 10, 2016 2:18 pm
by LargeyR
ruffstuff77_GER wrote:Hi everybody.
I dont think so!
Can you get someone to video the instruments so all can see ?
Posted: Sun Jul 10, 2016 2:40 pm
by Dan_
Mine boosts to 1.1 bar, isn't this normal?
Posted: Sun Jul 10, 2016 4:47 pm
by ruffstuff77_GER
Normal boost is 1.4 bar.
Oil was 120°C, water 100°C, outside 22°C
Will try to upload vid...
Posted: Sun Jul 10, 2016 6:35 pm
by Dragonfall
Oil @ 120 degs C !?!?!? :Eek: :LOL:
Was that after a few laps in on a track???
I've been the passenger in a FK being driven at max attack in 25 degree ambient and the oil peaked at 110 degrees.
Posted: Sun Jul 10, 2016 10:59 pm
by Loxy
I got up to122C at Croft after 6-7 laps and then it held around there and no higher. Water temps were 98C.
No loss of boost though.
Posted: Mon Jul 11, 2016 8:05 am
by ruffstuff77_GER
Had this Problem on the track and on the "Autobahn" :D
@Loxy
What ambient temp did you have on the track?
Posted: Mon Jul 11, 2016 1:05 pm
by Loxy
Pretty sure it was around 15C, not massively warm.
Posted: Mon Jul 11, 2016 5:59 pm
by FunkyRemix
ruffstuff77_GER wrote:and on the "Autobahn
What speed were you doing :twisted:
Posted: Tue Jul 12, 2016 4:23 pm
by sparkysp
I dont think so!
does it bleed off boost as it approaches the red line my G60 does the same bleeds boost off as you hit max revs its like a engine safety feature
cheers stu ..
Posted: Tue Jul 12, 2016 7:56 pm
by ruffstuff77_GER
@sparkysp
No Sir. The boost is missing all the way up rev.
Talked to HCTR. They have the same Problem and work on a solution.
They say its a Temp Problem from the air inlet and the hot air that dams up in the engine bay.
And as I remember the AC did lose cooling power when this Problem came up.
Posted: Wed Jul 13, 2016 11:18 am
by sparkysp
ruffstuff77_GER wrote:@sparkysp
looks like a trip to AMD and have that bigger intercooler fitted that uses the full space of the opening looks good but also cost a pretty penny
Posted: Wed Jul 13, 2016 4:35 pm
by ruffstuff77_GER
@sparkysp
Sry mate. But bigger intercooler does not help either. Tried the Wagner intercooler. Same Problem.
And the space for the cooler is very limited also.So the size factor is not the huge.
And the hot air still dams up in the engine bay.
Posted: Wed Jul 13, 2016 5:50 pm
by Akula_Type-R
this help for sure
Image Image
Posted: Wed Jul 13, 2016 6:48 pm
by ruffstuff77_GER
@Akula_Type-R
Very nice. This will suck the hot air out.
Selfmade or somewhere to buy? What Price???
Posted: Wed Jul 13, 2016 7:33 pm
by dweezle
Tegiwas carbon bonnet, rumoured around the £500 mark and due shortly, (which means a yr or 2)
Never owned a tegiwa bonnet so I'm unsure on fitments & quality, it looks to tame for my liking, the car needs an aggressive bonnet.
There's another bonnet available which is designed for intakes sucking in air, I can't remember who makes it though
Added in 9 minutes 38 seconds:
http://www.jcp-performance.com/honda/ci ... -hood.html
Posted: Wed Jul 13, 2016 7:51 pm
by WoodyzR
Wouldn't the Eventuri induction kit with scoop solve this?
Obviously will only draw in air from the outside and not under the bonnet.
Posted: Wed Jul 13, 2016 8:55 pm
by Loxy
Just a thought, is the car remapped or stock?
