Basically, when we drop off the drive onto the road and the wheel is on full lock there is quite a loud thumping noise from the wheels as if something is catching. Only seems to do it when you come of the kerb and not when the car is flat ( and on full lock ). In fact I'm just wondering if its because the car is so stiff and maybe the inside rear wheel is still up the drive/kerb/path as the noise does seem to come from the front left when the rear right might still be on the kerb, if you know what I mean?
We've had it back to Honda and they say nothing wrong.
Mind you they also said the indicator stalk is working fine even though it doesn't turn off all the time which is a bit frustrating.
Has anyone else had these problems?
Car has only done 1200miles and we've had a bad stone chip on the front bumper thats gone straight through the paint which is disappointing.
Apart from that she is well happy with it.
