1. Unwrap
2. Bite both ends off
3. Use as a straw
and here are some others
duckdodgersuk wrote:The Hunt beginsWe sell these at work, no idea if they're any good though.![]()
Composite Guru wrote:Just eaten a white one. Very addictive!!did you use it as a straw?
duckdodgersuk wrote:Don't use them as straws!Composite Guru wrote:Just eaten a white one. Very addictive!!did you use it as a straw?
WizardinBlack wrote:duckdodgersuk wrote:Don't use them as straws!Composite Guru wrote:Just eaten a white one. Very addictive!!did you use it as a straw?
Read this yesterday and went out and went to asda and bought a couple.
I write this having suffered from catastrophic kitkat failure after sucking my tea through one.
There I was biting the ends off the bar of delicious chocolate and positioning it for optimal tea sucking.
I proceeded allow the tea to flow through and the outcome was far from desired.
The wafer disintegrated into nothing and the surrounding chocolate
imploded, broke apart and sploshed into my cup of typhoo.
Cheers mate. kitkat and cup of tea ruined
