- Fri Jun 10, 2016 11:16 pm
#3857174
I'm not even sure if I want to do this, but I'm going test the water.
So what could I look to sell the following for as a package.
Jackson Racing Supercharger - Full Rebuild
Sent all the way to Embree machine in Missouri, USA for a full rebuild.
Within the build, the following was done...
• Rotor blades re coated in Teflon
• Replaced rotor timing gears
• Inspection of snout and pulley
• New snout and shaft bearings
• Replace pair of needle bearings with upgraded double seal needle bearings
•Rotor Assembly Rebuild and Supercharger Reassembly
•Leak tested
Oil changed.
Included in sale
Manifold and fittings
CPL High flow Fuel rail
RC 650cc injectors
Jackson Racing Boost Gauge
It's like a new unit. add in the injectors £££ fuel rail, belts etc.
What you think?
•Leak tested
Oil changed.
Included in sale
RC 650cc injectors
What you think?
Milano EP3 - JRSC - 295bhp
Cars, Tattoos & Women - Expensive Hobbies!
