Kyle_d wrote:Wow thats good lol. I thought exedy ones were oem? Anyway not saying clutch is going go was jus thinking if it did. Quite suprised at that lol.
I've done nearly 110,000 miles in mine and clutch is still fine. It's labour charges that make clutch replacement expensive. In terms of parts and maintenance CTR's are cheap to maintain if you know where to shop. There are people on this forum that break CTR's regularly so any major parts can be had for a fraction of Honda costs. Only things to have gone wrong with mine in 8 years were:
2 Injectors blocked - £250 each from Honda but got a full set off the forum for £70 with half the miles mine had.
Idler pulley bearings dried out and started squeeling - Honda replacement is £40 and can be changed quite easily by yourself.
Changed front brake pistons and seals due to brake imbalance. Kit was £70 from brakeparts.
Sun visor sheared off - £7 off forum
I've had quite a few punctures but that would be the same for any car. Have a look in the wheels and tyres section for recommendations on decent tyres that don't cost the earth.
It's only ever not started once and that was only because I'd flooded it from only moving it 3 yards the previous day.
I've been told it will need a chain, tensioner and guides in the next 10,000 miles or so which will set me back around £600 but you could sell yours long before that. I would seriously do your sums properly before changing and if you still think you will save money then go for it.
