By Sm1thy14
#3814513
Hi all, I've just dropped of my type r at honda in Derby to get the valves done. I'm slightly concerned that they might con me and not do it as I've read a few stories on honda not actually adjusting them and just checking them by a computer! I did think it was all manual checks. Il be picking it back up tomorrow night. Is there any way I could tell it's actually been done?
Cheers kurt
By Superman001
#3814546
Ask to go early before they have finished the service so you can have a look at the engine without its rocker cover.
By Superman001
#3814548
Sm1thy14 wrote:Il have a look then tomorrow. I hope they do it correctly to be honest. Will that be easy to notice? Cheers pal
Even easier to tell if you put a small piece of tape on the back of the rocker cover and if its still there when you collect the car you will no they have not touched it.
By Sm1thy14
#3814550
The problem is they have already got it, I dropped it of tonight and I'm picking it up tomorrow night so I can't now :(
By Superman001
#3814551
Once they have 'checked' the clearances with a feeler gauge it only takes about 15 minutes to clean the 2 contact areas where the old gasket was and fit the new with some Hondabond. You should call them and ask that you can see your engine with the rocker cover off.
By Superman001
#3814557
Sm1thy14 wrote:I just need to think of an excuse as to why is want to see it, but it's worth a shot I guess. Cheers lad
No problem, we are here to help in anyway we can. To be honest it took me until 3 years ago to find an awesome independent specialist that I trust to work on my cars and now I can watch as my car is worked on if I want.
By Sm1thy14
#3814721
Right lads, I got the car back and all seems ok, fully cleaned and hoovered and looks like all work done. Only concern is they used 0-20w shell helix fully synthetic and when questioned as the viscosity seemed low, he assured me that's the best oil for it! Will it be ok with that oil?
By Superman001
#3814724
Should be fine, a lot of guys on the Honda Karma forum swear by that oil.
By Sm1thy14
#3814726
Superman001 wrote:Should be fine, a lot of guys on the Honda Karma forum swear by that oil.
Cheers mate. You've been great! I know they did the valves as the managed to knock some paint that was already flaking off the rocker cover so now need to somehow get that done :(
By Superman001
#3814728
Maybe time to get yourself a custom rocker cover, the original red finish usually starts to flake off on the left hand side on most Type R's.
http://hondakarma.com/guides/which-oil-should-i-use.5/
By Sm1thy14
#3814730
Yeah I've been looking into it, ive been looking around on eBay but not found much, I did see a chap on Facebook tbat did it a long time ago. Just can't remember who it was :/
Cheers for the link too, piece of mind. I paid extra to get the fully synthetic, tbh I don't really rag it much so it will hopefully be ok.
