By AdamB92
#3784962
Use genuine Honda Type 2 coolant as per the owners handbook mate, get it from your local dealer they always have it in stock. I found some online but by the time you factor in postage you don't save any money.
By davey j
#3794912
Evans Waterless coolant is a slightly more expensive alternative. I run it in my track car. Higher boil off point, totally reduced pressure on coolant system and never needs changing unless you've changed hoses out or a water pump. We'll worth a look.
