Barney wrote:why is this a sticky ?I think it is because of me hosting the pages from the workshop manual for all that want to do the job correctly instead of guessing :thumbup:
365bhp/324lb/ft of 4.2lt V8 fun
PSNet - mjhamilton1975
Mr Anderson wrote:Every 25k.Ok thanks, so Im looking to pay for 1 hours labour work for this to be done?
Mr Anderson wrote:Maybe 2. The car will need to be left overnight as the clearances have to be checked on a cold engine.I see. Thanks, this will be the first time I get this done.
Yates wrote:im not too up on the lingo but is valve adjustment the same as adjusting the tappets? Because ive just speaking to a mechanic about valve adjustment & he said do you mean adjusting the tappets.Good question! I want to know as well....
Mr Anderson wrote:Maybe 2. The car will need to be left overnight as the clearances have to be checked on a cold engine.I'm taking my car in to TDi and they will be doing the valve clearances.
dibbles00 wrote:this is a point of discussion... most people say it needs to be stone cold but if you look at the workshop manual it actually says below a certain temp...Mr Anderson wrote:Maybe 2. The car will need to be left overnight as the clearances have to be checked on a cold engine.I'm taking my car in to TDi and they will be doing the valve clearances.
Question is:
How can they do this if I am driving down there for 1pm (very hot engine) and leaving at the end of the big service?
Shall I ask them about this as they certainly haven't told me anything about a cold engine is needed to check them
mjhamilton wrote: if you look at the workshop manual it actually says below a certain temp...).
mjhamilton wrote:
When I took mine to TGM I dropped it in the morning and they did the service and valve adjustment in the afternoon.. it has been perfect since... I personally and not convinced the engine should be ice cold and as I say above the Honda manual supports this
dibbles00 wrote:Okay, TDi have replied with the car's engine has to be under 38’celcium (100’F) and it is checked prior to adjusting with a laser thermometer (which backs up what you saidit wont make the engine harder to start.. that is a load of old toffee.. :scratch: it will only be like this if the job has been done wrong and the valves are now totally out of tolerance and opening too much or too littlemjhamilton wrote: if you look at the workshop manual it actually says below a certain temp...).
Can anyone tell me the actual reason for adjusting the clearances? Someone on here said that it has made his engine harder to start, so is it actually worth it in the long run?
