By the-bazman
#3866922
Hi guys.
Got a question, I’m going to be changing my brake pipes on my civic type R EP3 front to rear and was wondering if I can just get rid of the brake proportioning valve as the car has ABS ( bit confused why it has one ).
Has anyone done this before ?
By parsimony
#3866923
The proportioning valve makes sure the braking effort is biassed to the front. Remove it and you will lose rear traction on hard braking with or without ABS.
FN2 softer suspension?
What did you go for in the end? Looking at changin[…]
Literally sat waiting for AA on mine after i'd lef[…]
Mimms Honda Day, the largest Honda event in the UK[…]
