- Thu Jun 30, 2016 4:34 pm
#3857888
Hi guys, my front windscreen washers arn't working as they should, I can hear the pump whirling, there's plenty of fluid in the system, but when i try to use them I get an initial squirt that goes about 10cm up my screen then they stop, has anyone else had this problem and how do I fix it? Thanks!
Added in 1 hour 55 minutes :
sorted it! turns out there was a load of crap in my washer fluid under the pump.
had to take the front drivers side wheel off to get to the wheel arch, then take the arch out which consists of some screws and push clips to expose the pump, I then got a screwdriver under the pump to lift it free (get a bucket of some sort underneath first) all the fluid and crap came out. reverse process to put it all back together and jobs a goodun! hope this helps someone in the future
