- Tue Aug 28, 2007 8:20 am
#1679279
Guy's,
Below is the list of the parts required to change the Dashboard to suit an aftermarket Headunit;
39116-S30-G01 POCKET, AUTO RADIO 1
77251-SMG-E00ZA PANEL ASSY., AUDIO *NH167L * (NH167L GRAPHITE BLACK) 1
77256-SMG-E00 BRACKET A 1
77257-SMG-E00 BRACKET B 1
91551-SE0-003 BOLT, FLANGE, 5X7 2x
93913-14280 SCREW, TAPPING, 4X12 (PO) 6x
You need to change the brackets for each side as the original brackets are part of the double din unit - cant be used again.
You also need to supply your Chassis Number as Dashboard Shades differ!
The Dealer would need to change this for you also.
Regards
alltherouge
Regards
alltherouge
