Removed the lower bench part, that's quick & easy, but I can't work out how to remove the upper (folding) section of the rear seats...
Much obliged if anyone knows!?
Awesam wrote:In the boot there is a section on either side of the trim that can be taken out, im sure if u remove that u will see where its attached.Yeah, spotted those and popped one off, but still no joy!
Colinjy wrote:nope look harder, the bolts are under those two little trim bits.Hmmmm... guess I need to have another look then...
there a 13 if i remember correctly
same size bolts as the ones for the seat belts
