#3835291
Bit difficult to do a guide as there's a lot involved and various ways about doing it.
If you was to do it on a ramp. It'll be easier to drop the engine and box together out from the bottom and lift the car up into the air.
Without a ramp, you'll need an engine crane to pull the engine out from the top. You'll probably need to remove the gearbox first.
Alternatively you could remove the whole front end and pull the engine and box out the front.
