By lennybubble
#3822376
When you say seized do you just mean the nut holding the arm o ,, mine is too,, once that of does it just pull out,, andwheredid you get your bung,, thanks :bigthumb: :bigthumb:
By Kieran_CTR
#3822384
lennybubble wrote:When you say seized do you just mean the nut holding the arm o ,, mine is too,, once that of does it just pull out,, andwheredid you get your bung,, thanks :bigthumb: :bigthumb:
No the nut came off fine, it was the arm that was seized to the motor, so had to saw the arm off close to the wiper motor spindle thing! After that came off it was easy
Also got the bung from ebay
http://www.ebay.co.uk/itm/Black-Plastic ... 43d802ccfc
