Step 1. http://www.mattnsteph.f2s.com/Step%201.JPG
Step2. http://www.mattnsteph.f2s.com/Step%202.JPG
Step 3. http://www.mattnsteph.f2s.com/Step%203.JPG
Step 4. http://www.mattnsteph.f2s.com/Step%204.JPG
Step 5. http://www.mattnsteph.f2s.com/Step%205.JPG
Step 6. http://www.mattnsteph.f2s.com/Step%206.JPG
Step 7. http://www.mattnsteph.f2s.com/Step%207.JPG
Step 7.1 Removing the bumper.
Pull the plastic arch liner clear of the bumper. Then start at the arch end of the bumper and pull firmly. The bumper will start to come out of its clips. It will take a little bit of force so don’t worry!!! Work your way around to the other side. (Note: once the side edges of the bumper are free you can get your arm behind to help push the front out of its clips. The clips are below the lights). The bumper will now be free to move to where you want.
Step 8. http://www.mattnsteph.f2s.com/Step%208.JPG
Step 9. http://www.mattnsteph.f2s.com/Step%209.JPG
Step 10. http://www.mattnsteph.f2s.com/Step%2010.JPG
Step 11. http://www.mattnsteph.f2s.com/Step%2011.JPG
Step 12. http://www.mattnsteph.f2s.com/Step%2012.JPG
Step 13. http://www.mattnsteph.f2s.com/Step%2013.JPG
Step 14. http://www.mattnsteph.f2s.com/Step%2014.JPG
Step 15. http://www.mattnsteph.f2s.com/Step%2015.JPG
Step 16. http://www.mattnsteph.f2s.com/Step%2016.JPG
Step 17. http://www.mattnsteph.f2s.com/Step%2017.JPG
Step 18. http://www.mattnsteph.f2s.com/Step%2018.JPG
Step 19. Installing the switch.
Remove the furry cubby hole. It is fixed using two screws in the top and two clips (squeeze from the back to remove) at the bottom. Using your fingers push out the blanking plate. Push the switch into place and plug in the last remaining connector.
Now check that your window winds up and down.
Now turn on your ignition, your lights and press the fog light switch, jump outside and see the fog lights working
Now you have checked that all is working refix the panels in the drivers footwell and replace the bumper.
JOB DONE!
