I found it easier if you took the whole hand grip and the electric window switch unit out.
On the socket there are either a release clip at the top (door locks) and two release clips on both sides (electric windows) socket. They should just slide off when the clips are pushed in, or with the assistance of a small screw driver at the edges to prise it apart gently. 8)
One mistake I made was forcing the speakers off with a screw driver, I snapped the clips and them speakers are useless now.
There should be a clip at the top of each speaker and using a flat-head screw driver you should be able to push these in some-how, and you should be able to slide the speaker upwards and out they come... (this is looking at the plastic tabs I snapped off in the process)
There currently is no spacer brackets in the car audio shops. I was told I had to get some MDF brackets specially made to mount 6.5" speakers.
Should cost around 40 pounds including fitting.
Hopefully I should have mine sorted sunday afternoon when I get the connector plugs for the speakers.
