also what is needed to keep the passenger airbag working + stop the airbag light coming on?
if someone can tell me how i will then provide a step by step guide with photo's.
Wheel:
rear:
and yes i have used the search button and found this however still not 100% sure how:
Dunno about the FN2, but I had it out of my EP3 once to change the steering wheel. I imagine its probably similar.Thanks,
Disconnect the battery and give it half an hour (dunno if the half hour is really necessary but I didn't want to test the theory.
Behind the steering wheel and going in from the side (if you get me) there are two plastic removable covers, one on each side, under those is torx headed bolt which holds the airbag in, remove those (they are very tight) lift the airbag out and disconnect the cables and horn switch, job done.
Refitting is the reversal of removal.
Not that its of importance to you really, as yur SRS light is already on, but you should never disconnect or reconnect an airbag while the battery is on, because it will put on the airbag light and the system will need to be reset by a dealer.
Matt
