JackEP3Premier wrote:Johnnyswitch81 wrote:JackEP3Premier wrote:So pretty much cut it until the insert fits yeah? Does the kit naturally rest on this?
I have my air box stuck on the skuttle with strong Velcro tape with no sponge and mine does not rattle at all
Make sure you cover the nut on the heatshield when fitting, with something soft in case the air box scrapes on it, to be honest I have no movement on mine and it's fixed really secure, but I still covered it with sticky foam.
Ok so it does sit flush to your scuttle then if it velcro'd on? sweet dude thanks!
Yes mate, it fits perfectly flush to the skuttle, the Velcro tape came with the kit and works really well. Also the carbon air box bolts on via a bracket, and is also attached securely to the intake pipe so it shouldn't move at all.
Superman001 wrote:Shocking that a kit costing over £300 doesn't fit perfectly out the box but then again if people are going to keep buying them what incentive does the designer have to make an improved version.
Im pretty sure a new panel filter in a Hondata modded airbox with a cold feed will produce almost the same gains or be within 1bhp of the GM or TegM.
This kit does fit really well, I had no issues what so ever and the gains are much better than a hondata modded air box especially with a remap with 10x better induction noise produced, especially in vtec
