If so, you need part 6 below
About £7 from Honda, or use the one off your OEM hose, but it's a PITA to get off
Mickey C wrote:What happened is my sfs hose has been cut down i think to fit another manifold, as id bought this kit of another forum memeber and he has a different one.yep your SFS hose has been trimmed to fit an RBC mate.
Not to worry im just going fit it to a standard intake hose and ill get the little metal thing i need with it too
Mfisher wrote:What goes onto the right hand side breather bit on the intake pipe?It's a sensor mate to give readings of the air flow to the ECU
bluntcap wrote:Mfisher wrote:What goes onto the right hand side breather bit on the intake pipe?It's a sensor mate to give readings of the air flow to the ECU
