kamion wrote:Copper Grease - You normally place this on the back of the pad between the pad and the shimmy (the silver bit you clip onto the pad.) It's purpose is to prevent the brakes squeeling.9 Remove the pads, and when re-fitting, apply a small amount of high melting point grease (copaslip or similar) to the top and bottom of the pads as seen here.Sorry, I don't see what you mean by "top and bottom" of the pads. Where do you apply the grease? What is the purpose of the grease? Thanks.
