dubmas wrote:hi,No its to stop the piston turning so fitt the pads with the "pip" or "peg" you may have the wrong type for the Ep3 go back and have them do a check. Had the same problem no PIP so went back and had the correct ones
i fitted some mitex m1144 rear pads today. they fitted fine. but reading this again i realise there was no "pip" on the back of the pad that faces the piston "cross".
i therefore didnt align the cross on the piston to be at "12 oclock".
do you think this will have an adverse affect? ive taken it for a drive today and it seems fine.
i suppose the pip is added protection against the pad moving against the disc?
any ideas? has anyone noticed this on mintex pads?
cheers.
sam
3" B Pipe Oem A/b Stoptech BBK Tdi Tuned
