By BadBoy
#128476
Is there anyway of automatically cutting the feed to the starter switch once the engine has started?
By woolz
#210299
i really like this idea, but where else could i put it>?? becasue i use the cigi lighter for my phone charger!!
By neo
#210412
I got the starter button in mine!
But one thing i'm sure is that the relay isn't required!! it works without it fine and with less wiring!
By woolz
#212743
is this right??? what does the relay do then? why fit it?
By woolz
#212744
please someone fit it 4 me lol! ooo and also.. does it light up?
By BadBoy
#212754
Thinking about it you don't really need the relay as the swith will only send out power when pushed in.
Yes, it does light up.
By Dirtyhabits
#212764
So how much is the start button from Honda
By woolz
#212858
just ova £50 quid dude!
By Dirtyhabits
#212859
woolz wrote:just ova £50 quid dude!
Thank you M8t .... i am on the way to honda
By woolz
#212896
could someone plzzzzz do the diagram without the relay in it!! plzzz
By BadBoy
#212908
Basically just connect the positive and negative feeds from the ciggi lighter to your switch and then the output goes to the ignition wire bypassing the relay.
By woolz
#212909
where abouts will i pick up the ignition wire from?
By oompaloompab0i
#284565
i was trying to put it into my car today but i am using a relay (because the wires, if used without a relay, will burn out soon, if you keep sending 30 amp through it with each press everyday). yet the relay i found has only 4 prongs opposed to the 5 prongs in the diagram of that link. what do i do? also in diagram, tehre is like an 86,87 and other numbers that complement each prong, does it really matter whcih one is for which? thanks
By type r daddy
#301145
who is the guy who fitted the button in a different place???next to the stearing wheel, can anyone find the pics? cant find them
By BadBoy
#301492
type r daddy wrote:who is the guy who fitted the button in a different place???next to the stearing wheel, can anyone find the pics? cant find them
It was me :)
By Den
#322523
Does the button light up when just using the 3 wires into the actual button or is that what the other 2 wires that do this?
Den
