- Wed Oct 11, 2006 10:04 am
#1357889
Right! a quick update, i had to buy a new buton as i wasnt getting a refund! and i have tried the new button and YES it worked the 1st time,so i tried it again and nothing
Can someone please talk me through all the wires and colours, as i think i have done it right but sometimes it helps to get someone else to check your work.
1st question, im using the fag lighter to get the power to the relay, what wire is pos (power) and which is neg (ground) this is going IN to the back of the fag lighter?Is green and yellow is (ground) and black is live(power)?
and the live goes to position 30 on the relay? using the red wire?
ground goes to the 86 on the relay using the black wire? then from the same connector a thinner black wire comes out and goes in to the left hand hole in the little plug that plugs in to the button (if the little plug is layed down so it sits on the little plastic ridges as legs and you can see the silver bits facing you)
relay 87 connects to the thick black and white wire at the stearing wheel plug and a thinner red wire goes to the button and sits int he middle slot of the little plastic plug
now the last thinner wire is on its own and i have yellow and that goes straight to the right slot in the little plastic plug that fits in to the button
i think i have covered all that i need to check, please please please someone help me in pictures or directly chatting to me i dont mind i just want this to work!
LIFE! Sounds abit complicated to me!
Spoon N1/B pipe,AEM CAI.
