Has anyone polished the fuel rail or done a wire tuck etc?
Or is the only way to uprate the fuel rail (not doing that)
RM CYA wrote:It's a fuel rail. Just leave it and let it do it's job. Polishing things is gay.:badrazz:
RM CYA wrote:It's a fuel rail. Just leave it and let it do it's job. Polishing things is gay.Have you not seen what the fuel rail looks like?! :scratch:
Josh1921 wrote:Polishing it isnt impossible. It does come up but takes ages by hand. Its a lot quicker if you use the polishing tool on a dremel! Comes out like new. :bigthumb:Awesome, I've hand polished a set of alloy wheels before so I know the work involved haha, I have all the shizz somewhere in the shed so shouldn't be too bad
Eric_Sn@il wrote: i tucked the wires on mine, looks much nicer than the plastic over, polishing however is impossible, its all tarnishedExactly the pic I wanted to see, thanks man, any extended wires, problems id expect, advice?
Jameshop wrote:I have, it looks like a fuel rail. Liiiiiiiiiitle bit of a different situation regarding the paintwork. But if spending an afternoon polishing a fuel rail is your sort of thing, crack on.RM CYA wrote:It's a fuel rail. Just leave it and let it do it's job. Polishing things is gay.Have you not seen what the fuel rail looks like?! :scratch:
You should do the same about your paintwork, it's there to stop the shell from rusting, leave it do it's job cause polishing is gay!
Gangaran wrote:Get an aftermarket fuel rail. The OEM looks really :badrazz:
leeglf wrote:i thought about carbon wrapping mine but looks a bit too fiddly for me.I've done this with my oem fuel rail, I tucked the wires and ground off the metal lugs for the plastic wire casing, just tidied it up a little...it is fiddly to wrap it and it peeps off on the edges from the heat...check my thread out on "what's done to your ctr" for pics.
