Any advice would be much appreciated.
Sunny
w6ady wrote:You can buy tweeter mounts from Honda mate about £16 each. They replace the blanks on the inside of the mirrors. As for speakers you can mount a set of 17cm components in the doors you will need some mounts to put them on. I believe you can use some Vauxhall ones do a search or alternatively just use a set of mdf spacers as I used on my ep3. Not all 17cm speakers will fit as if the magnet is too big will foul the inner door skin. Before you buy check the measurements carefully. Adding sound deadening will get more from your speakers also.
