Also anyone know where I can buy the tweeter mounts for the wing mirrors.
Are the Focal Access 165 A1 speakers a good buy component wise.
mtailor wrote:Send Dalco, a registered trader on here a PM. He has all the stuff you require.
cosmicmarc wrote:Yeah I read that I think I may have to ring him as me and a friend want the tweeter mountsHe is a top bloke.
mtailor wrote:Comicmarc, did you manage to get hold of Steve(Dalco)?
mtailor wrote:If you are using the OE head unit, I don't know if the speaker outs have the power to drive the mids and highs effectively. An after market head unit should have a better power output. The sound quality will be better. To put it in a simple way, when you listen to music on the OE head, then using the same speakers with an aftermarket H/U, the sound difference and quality is night and day. Using an amp and taking good quality feeds from the H/U is a massive improvement too. An amp using outputs from the OE unit will not be as "clean" as an aftermarket with dedicate outputs.Thing is just how noticeable will it be running the focals on the oem unit with out amp compared to running the amp? I really dont like aftermarket h/u especially as they are black and the surrounds all silver.
Going back to your question, if I was keeping the OE H/U, I wouldn't spend that kind of money on a speaker set. A cheaper Alpine or Kenwood would be sufficient.
mtailor wrote:Have you tried to call him?There's no number mate the old ones been taken over by the new business.
