- Mon Nov 26, 2007 11:38 am
#1759111
If your looking to upgrade your front speakers but don't want to have to cut any metal...... here's the simple answer...
Focal Polyglass 165VRS.
Midbass driver mounted into door without cutting. 9mm mdf spacer used to provide a solid mount for the unit.
Midbass driver showing small neodymium motor unit.
Tweeters mounted into factory tweeter mounts.
The tweeter requires minimal trimming to fit it into the original mount. The midbass driver can be fitted without the mdf ring but using it does give it a firm mount and reduces the chance of vibration related noise. The crossover fit's neatly into the back of the door panel, just behind the handle.
