#1047505
For example . . .
If you leave your interior light on when your Type R is frosty / icy or been snowed on. It melts the snow, ice or frost on the top of the roof. Never had this happen on any of my other cars.
Have you learned any unusual little Type R habits lately ?
By Adambsmith
#1047506
As seen elsewhere today, someone has learned that the spare wheel does not fit on the front.
By Adambsmith
#1047507
The rear wiper will come on if you put the car in reverse and the front wipers are on.
By martin
#1047515
A bleeper sounds when I put the key in the ignition before I put on my seatbelt. :x
By sjw
#1047516
Adambsmith wrote:As seen elsewhere today, someone has learned that the spare wheel does not fit on the front.
That's in the manual, isn't it?
By sjw
#1047518
Adambsmith wrote:The rear wiper will come on if you put the car in reverse and the front wipers are on.
That feature always makes me smile. It's such an obvious little thing to do, but I've never seen it on another car.
By Adambsmith
#1047519
It is indeed - but not everyone knows it :wink:
By Adambsmith
#1047521
We had a Renault Scenic that did it and I think the g/f's Audi A3 does it too.
By Adambsmith
#1047523
The passenger seat always returns to the default position after it's been moved to allow entry to the back seats :x
By Nick
#1047525
The hollow on the inside of the boot on the top right actually closes the boot without having to touch the outside of the car - First time for me in a car !!
Also, if you sit at the lights in neutral and rev the engine, it won't rev above 5500rpm
Lastly, if you wash the car and water gets in the pipes ( standard ones that is ! ) when you first VTec it after washing, the mist out the back is like a Bond Car smoke screen :D
By LeeH
#1047532
You can actually manually adjust the temp gauge by +/- 3 degrees I found out yesterday :idea:
By Beejam
#1047535
Even ancient Rovers do that.
By bomberharris
#1047543
Adambsmith wrote:The passenger seat always returns to the default position after it's been moved to allow entry to the back seats :x
not a problem,if your like me theres only 1 seat in my car that i sit in and its not the passenger one :)
By LeeH
#1047544
Beejam wrote: Even ancient Rovers do that.
Yep, my coupé did and that was 1980's technology
By moNoKnoT
#1047546
LeeH wrote:You can actually manually adjust the temp gauge by +/- 3 degrees I found out yesterday :idea:
How can I adjust mine? I knew dealers can do this. :D
- Kevin.
By LeeH
#1047549
- Kevin.
Hold the button down for 5 seconds. Read it on here somewhere.
I had to adjust mine -2 as it always read high when it was frosty.
By Agg!3
#1047600
martin laird wrote:A bleeper sounds when I put the key in the ignition before I put on my seatbelt. :x
Not if you unplug the plastic connector under your seat it doesn't. :wink:
By Adamcivic
#1047612
If you have the door open for a while (while hovering for example) the interior light turns itself off - a nice touch :)
Also if you unlock the car but don't open a door it relocks itself.
By slamduncan
#1047628
The door panel moves ever so slightly away from the window when it is being wound down. this is why it doesnt remove the condensation from the window when its going down.
Been posted before but what the heck!
Also on the subject of locks, when it says to turn the key in the lock twice to "super lock" it, what exactly does it mean?
  • 50
