By connor.barker
#3865043
Replace my rear caliper about 5 months ago as was seized. Now it's starting to seize again. Anyone else have this problem or suggest anything else that could be causing it?
Sent from my SM-G920F using Tapatalk
By Norv
#3865044
Firstly, they're brakes. [emoji6]
Secondly, was it definitely a seized piston on the other caliper? It could be a seized slider stopping the brake pressure releasing again. Or even pads tight in the carrier.
I'd take it apart and have a butchers and go from there.
Sent from my LG-H815 using Tapatalk
By connor.barker
#3865045
Norv wrote:Firstly, they're brakes. [emoji6]
A mechanic had a looked and said it was the piston mate. Will take it into anther garage and see what they say. And sorry would blame in on auto correct but then I would be lying [emoji23]
By Norv
#3865048
I recently replaced both rears with calipers from brakes International. They were only about 65 each I think. In theory yours should be under warranty still. Did you go back to where you took it previously?
By Newton
#3865056
"A mechanic had a looked and said it was the piston mate."
I presume he took the wheel of and the caliper to check , or is he fitted with X-ray vision
