- Tue May 09, 2017 10:37 am
#3864255
Hi all,
Has anyone had to deal with their steering lock moving position? and if so how easy is it to adjust.
Reason I ask, is I had to undo my front hub nuts, and stupidly did so with the steering lock on. the result is that the steering lock position has moved from the front wheel being perfectly straight to a quarter turn to the left.
I'm assuming that I should be able to remove the steering lock mechanism from the column/shaft and rotate back round. But that seems to easy to be true.
