Needs some help. Currently doing some bits to my EP3 and noticed that one of the A/C pipework, underneath the car. is not bolted to anything.
The result of this has meant that the metal section of the pipework has been vibrating against the sub-frame and has almost cut a hole in the pipework.
There is a bracket on the pipe its self. but no bolt or obvious bracket anywhere else on the engine or sub frame. can anyone let me know where it is meant to be bolted to. any pictures would be much appreciated.
Bracket on AC pipework.
No visible bracket on engine or sub frame.
Cheers guys
