By Wayne-CTR
#3843124
Maybe the back piston is sticking slightly, or the the sliders are seizing up?
Does the wheel get warm during normal driving? Could also be that the handbrake hasn't been tightened correctly.
By Newton
#3843130
Does the back of the pad have the small pins in or are they just plain
as the pins stop the piston from rotating and not taking up the slack
pic in a short time
or are the the wrong pads
By 15repyt
#3843161
Mine did this give it time it time it will go. If you want to take the outer pad out and file the outer edge down slightly but it will flatten out eventually.
By 160mph_boy
#3843175
Yeah mine did this also last year when i got my new rear pads fitted... my sliders and pistons were working fine as well so! Can't remember exactly how many miles i done before they bed in and start making full correct contact with the entire surface of the disc, but it didn't seem like all that long.
