The Worlds Largest Independent Honda Type-R Club & Forum - "Often imitated, never duplicated"
  • Problem fitting yellowspeed coilovers ep3...
  • Information, speculation and anything else specifically related to Civic Type R EK9 and EP3
 #3865393  by Hartlepool jono
 Fri Nov 10, 2017 3:33 pm
Basically guys. Took some old tein dampers out and installing some yellowspeed coilovers. When installing. The track rod ends is loose in the coilove mounting point?? Confused as to why this would be... to note is I bought the coilovers used but virtually as new. My civic is a 51 reg. Was there a change with facelift?? Can't see this being the case. But don't knkw why the track rod ends would fit the tein and not yellowspeed. 100 sure the coilovers came off a ep3
Sent from my SM-G950F using Tapatalk
 #3865394  by gatecrasher3
 Fri Nov 10, 2017 7:41 pm
I believe there is a difference in size between the DC5 and EP3 track rod ends. Could they either have come off a DC5? Either that or the EP3 that they came off had DC5 track rod ends fitted to suit them.
 #3865404  by Newton
 Mon Nov 13, 2017 3:49 pm
Or have they been used with inverted track rod ends in which case they have been drilled out
have a look if the bore hole is parallel or tapered
 #3865405  by Hartlepool jono
 Mon Nov 13, 2017 3:54 pm
Hi think I got answer from my fb post. So these come with little collars which are usually tie wrapped to the coilovers when new. These are missing so I've just ordered a new set from tegiwa for 15 pounds . So hopefully all is good.
 #3865406  by Newton
 Mon Nov 13, 2017 5:18 pm
Did'nt now about these collars seems a bit strange then
so they just make these universal
What was the problem with the tein coilovers then, as I have these with the EDFC active pro electronic damping force
as you can set the damping force as you are driving
 #3865407  by Hartlepool jono
 Mon Nov 13, 2017 5:23 pm
Newton wrote:Did'nt now about these collars seems a bit strange then
The tein ones were on when I bought the car. They are just the basic model. The car is turning into purely a track car which was always my intention. The tein are a little soft. They would be good as a alternative to lowering springs and as a fast road set up though. Just in process of getting a Fia approved roll cage fitted. Few other bits a bobs planned for over the winter. I should really do a build thread but the car is too far on lol.
 #3865408  by Newton
 Mon Nov 13, 2017 5:29 pm
So we may see you on track then
Off to Snetterton this saturday last outing of the year
 #3865670  by Davey.01
 Thu Dec 28, 2017 12:21 pm
Hartlepool jono wrote:Hi think I got answer from my fb post. So these come with little collars which are usually tie wrapped to the coilovers when new. These are missing so I've just ordered a new set from tegiwa for 15 pounds . So hopefully all is good.
Could you post a link for these please ? I can’t find them on tegiwa’s website
Recent Topics
User avatar Squealy front brakes
Mon Oct 22, 2018 4:49 pm
User avatar Newb ☺️
by Superally 04
Sat Oct 20, 2018 9:17 pm
User avatar bondyboy's NHB EP3 -2017 EuroTrip pg15
by kinky_boy
Fri Oct 19, 2018 10:31 am
User avatar Hello
by bondyboy
Sun Oct 14, 2018 2:28 pm
User avatar Thinking of buying FK8 type R
by Stevie_CTR
Sat Oct 13, 2018 7:38 pm
Twitter
About Us
CTRO™ was the worlds first and largest Civic Type R club and forum. Established in 2002 it brings together people from all over the world to discuss their one love of Type R's. Now fully updated for 2015 the new forum based on BBOOTS PhpBB® Unofficial HTML5/CSS3 Theme. It’s Clean And Crisp Design Looks AWESOME Across All Browsers And Devices.
Don't forget to check out our huge Facebook group and Twitter Pages for all the most upto date goings on in the world of Honda and the Type R Brand.
CTRO
Established : 2002
