The overall average mpg seems ok but the current mpg indicator jumps about too much.
The car seems to drive ok otherwise.
Sedge probably joined the party, and there endeth the party.
summ0004 wrote:Just seem that mine drops quite low when im not even even driving it that fast.perfectly normal, it tells you exact to the second how you are driving, if your are coasting you will get 100mpg and over, slight touch of the peddle will use more fuel, also its different if you are going up or down a hill. its to the second information perfectly normal
using 50% throttle giving 20 mpg seemed a bit crazy and then it would shoot upto 100 mpg the next second when coasting.
Maybe the MAF sensor could need a clean or is slightly faulty. Might try and reset ECU to see what happens.
Whiteheadgraeme wrote:You've asked this question on Civinfo????Did he get the same answer
Robert Burns wrote:NoWell what answer did he get :scratch:
Robert Burns wrote::cooldude:
"If you jump up and down on the throttle you can pretend its a graphic equaliser
Upsets the passengers though."
summ0004 wrote:Just seem that mine drops quite low when im not even even driving it that fast.It's giving you the exact conditions the engine is under for the last second or so of driving, if you floor it the car will drop down probably below 20 mpg and when you are coasting the engine is idle so it's not using hardly any fuel and you are still moving so in effect smalll amount of fuel for a large distance covered = 0ver 100 mpg. Simples.
