I'm thinking about it as I have a piper cat back, DC5 manifold and Hondata air box mod and wondered if it's worth getting?
TR
Norv wrote:It also works out pretty cheap as your Ecu gets upgraded and your immobiliser works as normal, then once you have any more mods done you can get another custom remap. It spreads the costs a bit and means you get a little bit more fun a bit earlier on! Like I said above, I have the before dyno results. Will have the after results in the next week or 2.Did you get it on the dyno?
