Finally got it going after about 10 minutes of turning over feeding the throttle and was revving funny and kicked out alot of white smoke!
Will it be ok? It seems to be ok now, but is there long term effects? Im gutted
Abraham Lincoln wrote:don't believe everything you read on the internet
54typeRchris wrote:Get yourself a hydro sock man. Mine is much better with one fitted. :thumbup:+1
54typeRchris wrote:Get yourself a hydro sock man. Mine is much better with one fitted. :thumbup:It might help against water spray, but going through a huge puddle with or without one will have the same result. The only way it could stop a huge puddle going through the filter is if it were 100% waterproof, in which case it would restrict air flow badly.
bigbenson wrote:+2 :thumbup:54typeRchris wrote:Get yourself a hydro sock man. Mine is much better with one fitted. :thumbup:+1
j wrote:oem all the way+4
