I could drill a hole there, but I don't wanted to remove the needles because is risky....
so I put the led here:
acidstrato wrote:i wired mine today however its not lightingit'a all here in this post. remember to put the LED right and use a fuse just in case.
i bought a flashing led from halfords its already wired so can only assume there is a resistor insider the casing. i wrapped the black wire around a bolt next to the footrest is this sufficient for an earth or is this letting it down do you think?
